Cell Phones Logo
J
Janet Coleman Posted on Feb 22, 2017
I can[t get the control panel to open - iPhone Apple Cell Phones
2helpful
What will cause a sunroof not to close properly on a 2007 Milan
A lot of thing's , has sensors , switches , a control module , relay's etc....
The roof opening panel is an electronically operated panel that can be opened or closed by pressing a switch located on the overhead console. It also has one-touch open, one-touch close, one-touch vent open and one-touch vent close features.
Roof Opening Panel The roof opening panel assembly uses an integrated motor and module to operate the roof opening panel. The roof opening panel motor and module are installed new as an assembly. The roof opening panel is an electronically operated glass panel that can be opened, closed or tilted by the roof opening panel switch. Actuating the switch in either a forward or rearward motion supplies a ground to the roof opening panel motor/module. The roof opening panel has one-touch open and one-touch close features that are activated when the switch is momentarily pressed to the double detent OPEN or CLOSE position. These functions are controlled by the roof opening panel motor/module.
The roof opening panel motor must be initialized whenever the roof opening panel motor has been removed from the roof opening panel system, the roof opening panel assembly has been removed from the vehicle, a new roof opening panel motor has been installed or a new roof opening panel assembly has been installed.
Plus the mechnical parts of it .
Visual Inspection Chart Mechanical Electrical
  • Roof opening panel
  • Roof opening panel frame
  • Roof opening panel drain hoses
  • Roof opening panel lifter assemblies
  • Roof opening panel trough
  • Roof opening panel air deflector assembly
  • Roof opening panel seal
  • Roof opening panel shield
  • Battery junction box (BJB) fuse 33 (20A)
  • Smart junction box (SJB) fuse 12 (7.5A)
  • Circuitry
  • Accessory delay relay
  • Roof opening panel motor and module assembly
  • Roof opening panel switch
tip
Set firefox as ur default browser
Windows 7 and Vista
  1. Click on the Windows logo to open the Start menu, then select Control Panel. The Control Panel window will open.
  2. Click on the link labeled Programs. The Programs panel will open.
  3. Click on the link labeled Set your default programs. The Set your default programs panel will open.
  4. In the Programs list on the left side of the window, click Firefox.
  5. In the right side of the window, click Set this program as default.
Windows XP
  1. Click the Start button, then click on the Control Panel icon to open the Windows Control Panel.
  2. Click the Add or Remove Programs icon to open the Add or Remove Programs applet.
  3. On the left side of the window, click the Set Program Access and Defaults icon.
  4. Click on the Custom radio button to expand the Custom category.
  5. Underneath Choose a default Web browser click the radio button next to Mozilla Firefox.
  6. Click OK at the bottom of the window.
if it helps u...pls vote
on Oct 03, 2010 • Computers & Internet
Sun roof won't close 2004 Ford Explorer
The roof opening panel is an electronically operated panel that can be opened or closed by the roof opening panel switch. Actuating the switch in either a forward or rearward motion supplies a ground to the roof opening panel motor. The vent and soft-stop functions are controlled by the roof opening panel motor. These positions are obtained when an internal motor cam opens the roof position switch, removing the ground from the switch. The roof opening panel has an express open feature activated when the switch is pressed momentarily. The roof opening panel is closed by continuous activation of the switch until the sunroof stops movement. This function is controlled by the roof opening panel motor.
  • Opening shield
  • Roof panel frame
  • Opening shield guide feet
  • Central junction box (CJB) fuses:
    • 2 (20A)
    • 29 (5A)
  • Battery junction box (BJB) fuse 1 (60A)
  • Roof opening panel control switch
  • Circuitry
  • The roof opening panel does not open or close
  • Central junction box (CJB) fuse:
    • 2 (20A).
    • 29 (5A).
  • Battery junction box (BJB) fuse 1 (60A).
  • Circuitry.
  • Roof opening panel control switch.
  • Roof opening panel motor.
  • Go To Pinpoint Test E .
Do the power windows and power locks work ?
E6 CHECK VOLTAGE TO THE ROOF OPENING PANEL MOTOR - CIRCUITS 400 (LB/BK) AND 1173 (BN/OG)
  • Key in OFF position.
  • Disconnect: Roof Opening Panel Motor C920.
  • Key in ON position.
  • NOTE: Activate accessory delay relay for this check.
  • Measure the voltage between roof opening panel motor C920-4, circuit 400 (LB/BK), and ground; and between roof opening panel motor C920-7, circuit 1173 (BN/OG), and ground.
  • Are the voltages greater than 10 volts?
Yes
GO to E7 .
No
REPAIR circuit 400 (LB/BK) or circuit 1173 (BN/OG). TEST the system for normal operation. If you can't do electrical testing , there is a manual way to close it .
Roof Opening Panel Manual Operation
  1. Remove the overhead console. For additional information, refer to Overhead Console in this section.
  1. Insert a hex-head screwdriver in the center of the manual drive slot to depress the release pin. Rotate the screwdriver clockwise until the roof opening panel is closed.
How to Open the Control Panel?
Click the bottom-left Start button to open the Start Menu, type control panel in the search box and select Control Panel in the results. Way 2: Access Control Panel from the Quick Access Menu. Press Windows+X or right-tap the lower-left corner to open the Quick Access Menu, and then choose Control Panel in it
Installed driver as per destructions' but then zip!, re installed, naah. the pen still works but without any pressure, so at the moment, the driver is uninstalled just using it as a mouse. help
i am going to give you some ideas on how to resolve these issues.
1. go to control panel and open device manager to see it the device is showing up and check for up to date drives.
2. go to control panel and look for locate and other sensors and open the folder.
3. go to control panel and open action center go to windows program compatibility troubleshooter
4. go in to control panel open auto play is if the device show up in the other devices than select proper settings
5. go to control panel and open devices and printers and find the add a device and it will display in this area
6. go into control panel and open personalization fold change mouse pointers options
7. IF ALL FAIL HERE THAN YOU SHOULD GO TO CONTOL PANEL SELECT TROUBLESHOOTING FOLD AND FOLLOW INSTRUCTIONS.
8 . you may all so have firewall + antivirus + malware issues or conflicts with other security software and you will have to go in to each security appt. and exclude the files from the scan or interruption.
thank you rod
2helpful
4answers
Where is the control panel for inspiron?
From the main page, click on 'start'. Then click on 'settings'. Then click on 'control panel'.
Control panel not open
Just format u r whole hard disk and install new operating system, that can show u control panel
2helpful
3answers
How to open firewall
Hi
Which firewall u want to open, windows firewall
I am trying to connect my webcam with out the disc
Instructional steps
  1. Click the "Start" button, then click the "Control Panel" icon on the Start menu. This opens the Control Panel window.
  2. Click the "Switch to Classic View" link in the left-side navigation pane of the Control Panel window if the Control Panel is not already set to classic view. When the Control Panel is set to classic view, you will see the "System" icon in the right-side pane.
  3. Double-click the "System" icon in the Control Panel window. This opens the System Properties window. Click the "Hardware" tab; then click the "Device Manager" icon to open the Device Manager window.
  4. Click to expand "Sound, video and game controllers" in the list of device categories in the Device Manager window. Double-click the "Microsoft LifeCam" icon. This opens the Microsoft LifeCam Properties window.
  5. Click the "Driver" tab in the Microsoft LifeCam Properties window; then click the "Update Driver" button. This opens the Hardware Update Wizard. Follow the wizard prompts to install the Microsoft LifeCam VX 1000 driver and complete the process.
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
