Firmware Update is needed.
FUNCTION IMPROVEMENTImprovement of Disc Servo firmware to correct "DRV ADJ err" or "DI read err" error message appearance.
COMPATIBILITY INFORMATION
1.) If this model is used in combination with PDW-U1 or PDW-U2 ,upgrade XDCAM drive software to v2.3.2 or V3.1.1 or higher respectively.
2.) Windows & Mac FAM Drivers must be upgraded to V2.3.0 or higher beforehand
3.) XDCAM BROWSER must be upgraded to V1.3 beforehand.
4.) CONTENT BROWSER must be upgraded to V1.1 or above beforehand
5.) If PDW-F800, PDW-HD1500 or PDW-F1600 is used in combination with this model, it must first be upgraded to V1.71 or higher.
6.) HDCA-702 used with this model must be upgraded to V1.10 or higher.
CAUTION ABOUT UPDATE PROCEDURE
1.) Execute "All File Save" to Memory Stick before starting the upgrade,after the upgrade please execute "Factory Preset" followed by "All File Load" from MS.
2.) Be sure to use external DC Power,Battery not recommended.
3.) Implement software update without disc inserted.
4.) Set VDR power save switch to STBY position.
5.) Disconnect all I-Link and Audio cables.
6.) If the Power is turned OFF during the process,restoration of the software package will not be possible, be careful.
7.) Follow the installation instructions in the Release Notes.
https://pro.sony/qf_CA/product-resources/software-firmware/1237492951598
https://pro.sony/s3/cms-static-content/operation-manual/3297517131.pdf
Thank you for the auswerte.
Thank you for the answer. . ..
