We have recently received these scanners but don't have a USB cradle to use Windows Mobile Device Center to install software. Is it possible to do this via an SD Card and if so how? I have an SD card in the device but I can't locate it once I power it up. Any assistance would be greatly appreciated as we want to roll these out to our staff to start using with our WMS. Thanks Matt
SOURCE: Pocket LOOX T830 conection problems
In Settings-->Connections-->USB TO PC, uncheck the "Enable advanced network functionality" helped the PDA Phone work with my laptop.
SOURCE: Windows Mobile Device Center (Vista SP1 32bit) Can't sync with my IPAQ HX2490b
For the Samsung i760, disable "advanced network functionality" in the "USB to PC" setting by uncheckmarking it. Then Vista and WMDC will detect the i760 properly...
SOURCE: Win Mobile Device 6.1 Vista will not Connect
Slmgato: have you tried to delete the old pairing on wmdc?
also to the other users: check the usb charge port on the tilt. Make sure it has not been bent or the pins have not been damaged. My tilt recently was damaged and now i can't charge or sync, but i can buy the replacement port for about 10 bucks and solder it myself.
SOURCE: not detecting device and i dont have driver software
Download and install the following software to install your 120GB External Drive: http://www.simpletech.com/support/support_downloads_storagesync1.42.php
SOURCE: I bought a 2GB SD card for my Kodak EasyShare C330 Camera
After having the same trouble, I installed a 1 gb card and it worked just fine. It appears the Kodak C330 won't recognize a 2 gb car.
