SOURCE: printer
Heads are clogged. Has it been sitting for an extended length of time? Ink will dry up in the heads and tubes. Alot of work to take apart and clean and may still not work. Try to get a service manual at justmanuals.com
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
SOURCE: Epson R230 ink & Paper Lamp Blinking
could someone show us how to open the r230? im having hard time cleaning the waste ink pad because i cannot open the r230..
SOURCE: Printer will not print ,paper comes out blank
Put new in cartridges in printer.
Page prints out blank.
Have cleaned the print heads 3 times.
Need help!
SOURCE: Epson 4000 manual head cleaning
Epson Stylus Pro 4000
Hey I have had my printer for 6 years and have had the same problem. I had to manually clean it and It saved me a chunck of change. I mixed equal amounts of amonia, acohol and windex in a bottle then I set my printer on replacing the blades. Once it was positioned I turned it off and removed the plastice cover over the ink tubes. With gloves I unscrewed each color from the top. The ink will run back into the tanks but dont worry. be careful not to loose the small rubber seals inside these tubes.Place a paper towel folded under the ink heads where the paper is printed on. I had a small insulin syringer that I put fluid in and I gently pushed fluid into each ink hole. I did this several times before I got the inks to flow onto the towel and I let it sit for 20 minutes or so. I then screwed all the tubes back on each color. I removed the paper towel , restarted my printer and ran a full power cleaning. Dont be concerned like I was about the ink wasted because remember your inks flowed back into the tanks when the suction was broken. You must do the power cleaning to force the air out of the chambers and you waste very little. My printer runs like a champ the first print was awesome. It takes about 45 minutes so be patient and careful.
Here is what you will need:
Paper Towels sm phillip screwdrive
Rubber Gloves small syringe
Solution /acohol-amonia-windex
A lot of Patience
