Refrigerators Logo
Tobias Funke Posted on Feb 20, 2017
Frigidaire upright frost-free Freezer model LFFU1765DW suddenly stopped working BUT here's the fix below
Our Frigidaire Freezer suddenly stopped working after ~10 years. The Frigidaire model LFFU1765DW was in perfect shape and lightly used so it seemed like a waste to just get rid of it. A little research showed me that I could check the controller which is a little part that connects to the compressor. A simple smell told me that it had burnt out and this was confirmed by a simple resistance check. Hopefully this helps someone in a similar situation. Once installed, I let the freezer run for a day and checked the internal temp and it was at -9 oF and seemed fine. Time will tell. Frigidaire Refrigerator Freezer Electronic Control Assembly 297051000 is the actual part number and works on several different models. Part Number 297051000 replaces 1157363, AH1149321, EA1149321, PS1149321. This is the cross reference I found online please verify first: Kenmore 25324042102 Freezer Kenmore 25324042104 Freezer Kenmore 25324082102 Freezer Kenmore 25324082104 Freezer Kenmore 25324092103 Freezer Kenmore 25324092105 Freezer Kenmore 25324722102 Freezer Kenmore 25324722104 Freezer Kenmore 25324752104 Freezer Kenmore 25324752106 Freezer Kenmore 25326042100 Freezer Kenmore 25326052100 Freezer Kenmore 25326052102 Freezer Kenmore 25326062100 Freezer Kenmore 25326062102 Freezer Kenmore 25326722100 Freezer Kenmore 25326722102 Freezer Kenmore 25326732100 Freezer Kenmore 25326732102 Freezer Kenmore 25326742100 Freezer Kenmore 25326742102 Freezer Kenmore 25327042700 Freezer Kenmore 25327042704 Freezer Kenmore 25344733100 Freezer Kenmore 25344733102 Freezer Frigidaire AFFU1766DW4 Freezer Frigidaire AFFU2067EW2 Freezer Frigidaire CFU17F3AW9 Freezer Frigidaire FFU1724DW3 Freezer Frigidaire FFU1724DW5 Freezer Frigidaire FFU1724DW7 Freezer Frigidaire FFU1764DW4 Freezer Frigidaire FFU1764DW6 Freezer Frigidaire FFU1764FW0 Freezer Frigidaire FFU1764FW2 Freezer Frigidaire FFU1764FW4 Freezer Frigidaire FFU1767FW0 Freezer Frigidaire FFU17FC5CW7 Freezer Frigidaire FFU17FK0DW4 Freezer Frigidaire FFU17FK0DW6 Freezer Frigidaire FFU2064DW4 Freezer Frigidaire FFU2064DW6 Freezer Frigidaire FFU2064DW8 Freezer Frigidaire FFU2065FW0 Freezer Frigidaire FFU2065FW2 Freezer Frigidaire FFU2067FW0 Freezer Frigidaire FFU20FK0DW4 Freezer Frigidaire FFU2124DW13 Freezer Frigidaire FFU2124DW15 Freezer Frigidaire FFU2124DW3 Freezer Frigidaire FFU2124DW5 Freezer Frigidaire FFU2124DW7 Freezer Frigidaire FFU2124DW9 Freezer Gibson GFU1764FWA Freezer Gibson GFU2065FWA Freezer Frigidaire GLFU1767FW2 Freezer Frigidaire GLFU2067FW2 Freezer Frigidaire LFFU1765DW11 Freezer Frigidaire LFFU1765DW13 Freezer Frigidaire LFFU1765DW15 Freezer Frigidaire LFFU1765DW9 Freezer Frigidaire LFFU2065DW10 Freezer Frigidaire LFFU2065DW8 Freezer Frigidaire PLFU1778ES0 Freezer Crosley R22CW13 Refrigerator Crosley R22CWF0 Refrigerator Crosley R22CWF1 Refrigerator Good luck!
Our Frigidaire frost frost free upright freezer from day one has frost build up on the food inside the packages. The frost is not a problem in the freezer itself, but on the food. Freezer burn occur
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Do you have a manual for a Frigidaire Freezer upright with model number FFU1464FW1
Hello Lasondra, that's a great question!
I have successfully located the Owner's Guide of your Frigidaire freezer, FFU1464FW1. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect! - Z
Frigidaire Manual Search Results
1helpful
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
1helpful
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
2helpful
Fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
