Setup procedure and set up codes for many popular brand remote controls are given. Visit the site linked here. http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
SOURCE: sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
SOURCE: i ned new remoute i boght 4 non of them works
Hello Direct Code Entry 1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button. 2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit. 3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes. 4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of
Just buy one Philips Universal Remote control [MODEL NUMBER CL 034]. Your proscan TV is listed in its codes. Codes are:
0704 0312 0103
the other codes for your brand.
You will get its manual also with it, describes all the proceedings and codes for different set to which it can be used. OK.
Direct Code Entry
button.
flashes.
