My older kenmore electric stove keeps getting some kind of a warning beeper" & displays "F3" on the display. I press cancel & it goes away for about 15 seconds & then starts again. The top burners work but the oven keeps turning off every time the beeper starts back up. HELP!
Hi
F3-E2 Error indicates
a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the door
appears to be closing fine then it is the control board that is bad and should
be replaced. Hope this helps...please post back for further assistance.
Daniel
oventemperaturesensorrtd
