2nd battery does not seem to be a viable option, reduce the suction power if u require less and it should work for 25 minutes approximately. (hope u know it automatically stops when dust the cup is full)
DC59 will display a blue indicator light at the base of the hand grip while the machine is taking in power. The light will go out when the machine is fully charged. DC59 will take 3.5 hours to charge fully when the charge is completely depleted, but it will take less time than this if there is still some charge remaining on the battery after use.
Please note, the machine's intelligent control software is designed to ensure the battery only takes in enough power to recharge, and to keep itself topped up. It's safe to leave the machine connected to the charger at all times when not in use - the machine is designed to be stored in this way, so it's always ready to go when you need it.
From the information you've provided, I'm not clear on whether or not you're finding your DC59 works as normal once the blue charging light goes out, or whether it's not working at all. To make sure everything is correct, please get in touch with our experts directly. We'll be happy to talk you through some simple diagnostic checks when you have your machine easily to hand.
You can reach the Dyson Customer Helpline by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
In order to confirm why your DC59 is behaving in this way, we would need to take a few further details from you - including whether or not your machine pulses on and off before shutting down, and whether it displays any solid or flashing coloured LED lights.
When you have your machine easily to hand, please call our freephone UK Helpline on 0800 298 0298. Our experts will talk you through some simple diagnostic checks to pinpoint the cause of the issue. If they determine that a replacement part is needed, they'll also be able to confirm if you're still within your free Dyson 2-year parts and labour guarantee.
We'll look forward to speaking with you. Just to let you know, we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
It's quick and easy to remove DC59's clear bin, which will allow you to remove any fluff or debris from the mesh shroud using a soft brush or dry cloth.
Press the red bin base release catch once, as if you were emptying the machine. Then with the bin base still open, press the same red catch down firmly a second time to disengage and remove the clear bin.
When the clear bin has been removed, you can wipe the bin and the rubber seals with a damp cloth to remove any clinging dust. Make sure all parts are completely dry before reassembling the machine. Please do not wash or submerge the clear bin or cyclone pack - this can cause damage to your DC59 not covered under guarantee.
I hope this helps, but if you'd like any additional guidance you're welcome to call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
The Dyson DC59 cordless vacuum has two LED indicator lights on either side of the handgrip, which you'll see where the battery attaches to the handgrip. These will flash to let you know when there's less than 1 minute of charge remaining.
Once the charge has depleted, the machine will shut off - the power won't trail away gradually as with some cordless products.
If your DC59 is making an intermittent pulsing noise when you hold down the on/off trigger, this is likely to be because a blockage in the motorised floor tool, wand or bin inlet is preventing airflow passing through the vacuum. If this is the case, please follow the steps shown in the video below to clear any obstructions:
I hope this answers your question, but if you'd like further assistance from our experts you're welcome to call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
A green light flashing when you try to use your DC59 could mean the battery has no power. If you're confident it's been allowed to charge for at least 3.5 hours, it's possible that the charger cord isn't connecting correctly with the machine itself, so no power is reaching the battery. This is more likely to occur if you're recharging the machine in the docking station, and the charger cord isn't correctly positioned.
We're happy to help you check for and resolve this - if a replacement part is needed we can also confirm if this is covered under our 2-year parts and labour guarantee. When you have your machine to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
