Refer to Sony KDL 55EX500 Troubleshooting Manual Protection Mode Symptom... 5X Blink - TCON & HFR Failure The 5X blink protection mode indicates a communications error between the TCON/HFR board and the MT5388 microprocessor on the A-Board.
First replace the TCON/HFR Board if the 5X protection mode blink pattern occurs. If the TCON/HFR Board does not repair the problem then replace the A-Board.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
You have a couple of problems if you are sure there are 2 different blink codes. 13 blinks indicates a backlight balancer error which would explain your no light condition. 14 blinks would be a TCON board error which is the driver board for the LCD screen. Either error would keep the screen black.
Just a copy from Sony:
the TCON/HFR board and the MT5388 microprocessor on the A-Board. First
the A-Board.
many bad lcd panels will show issues like this check the menus and if theyre bad its likely a bad lcd panel i'd complain to sony and see if they are extending the warranty for this issue as some xbr panels were defective
