Question about Canon imageRUNNER 3300 All-In-One Laser Printer
How to remove the error E000261-0000 of cannon ir 3300
6ya staff
SOURCE:
Cogz
Chris Coughlin
  • 1326 Answers
SOURCE: E000225 & e000019 error code
The error code E0019 is the waste toner bottle is full you need to empity out the waste toner bottle and make sure the neck of the bottle is totaly clean and clear, a sensor reads dirt on the neck that the bottle is full. To clear that code after cleaning the waste toner, turn the main power switch off on the right side of the copier. The waste toner bottle is on the left hand side toward the rear of the copier and is held in with one screw. The E00225 deals with the scanning lamp. you will have to replace the lamp and the lamp PCB as a set to solve that problem. Good Luck...
Posted on Nov 10, 2008
Ronnie Gregorio
  • 118 Answers
SOURCE: Canon IR-3300, error 354
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory , if you are try to change the counter pcb to get rid of high meter reading this error is possible, this a security measure of canon to prevent meter tampering
Posted on Jul 15, 2009
Anonymous
SOURCE: Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Posted on Nov 20, 2009
Anonymous
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Posted on Feb 11, 2010
hamzaskilltd
amir hamza
  • 318 Answers
SOURCE: error code e000002-0000 canon ir 3300
fixing assembly low temperature
Posted on Jun 26, 2010
Canon ir 3300 which side is fuser
Sir
clear the error codes in service mode-
Take the help of service engineer.
Thanks.
Dec 20, 2014 | Canon Office Equipment & Supplies
ERROR 100 IN CANON I R 3300
this problem Related to laser unit faulty ot ip board problem
Aug 30, 2014 | Cannon Office Equipment & Supplies
Ir3300 e805 error sollution
if cannon ir 2200-3300 shows error E00805-0000 THEN fixing fan is not workig fan is jam oiling d fan then fan is not work change fixing fan.
Jul 15, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
I have a cannon ir 3300 machiene and occured a problem with a error code e000000-0000 please help me out to remove this problem my technician has asked me to change the filament which is worth 12000.w
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
Feb 17, 2014 | Cannon Office Equipment & Supplies
My cannon ir 3300 machine show me Error code E 000530-0000 from last 2 days please give me solution for emergency
My cannon ir 2200 machine show me Error code E 000530-0000 from last 2 days please give me solution for emergency
Sep 09, 2010 | Office Equipment & Supplies
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS
Apr 29, 2009 | Office Equipment & Supplies
Error code E00003-0000
The film (plastic) film is probably torn from a piece of paper that got jammed between the upper and lower section causing an overtemp lockout condition.
1. Remove left paper door.
2. Remove conector rear plastic(black) and fuser shields(2) screws holding fuser cover shield and unplug (3)connectors,2on the rear and a small one on the front lower right of fuser unit
3. Remove (2) assemlbly mounting screws one at rear and one
on the front sides.
4. remove unit and purchase new complete unit from cannon
5.Installed new fuser by reversing above steps.
May 28, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
128 people viewed this question
Clive
Clive
old marine
old marine
Ekse
