Nov. 3, 2017 - The Boating Forum - mercury torque specs - im looking for mercury powerhead torque ... Proportional Serif, Monospace Serif, Casual, Script, Small Caps ... sorry for the novice question, but is this correct for marine engines? if so, ... 4-16 - titled POWERHEAD Crankshaft, Pistons and Connecting Rods (4 Cyl.) ...
Missing: 2013 cap
PDF
information. The description and specifications contained herein were in effect ... Name of engine manufacturer: Mercury Marine Technology Suzhou Co., Ltd. Address: ... 4 stroke. Identification of Engines Covered by This Declaration of. Conformity. Name of ... in loosening or disengagement of the steering link rod. This can.
Jul. 17, 2013 - I think those bolts are 5/16 and for clean dry threads 20 ft-lbs is roughly the rating. That's for a grade 5 (3 marks on the head) but marine engines ...
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." How to Decide Between Two or Four Stroke Outboard Boat Engine
Why did you need to clean the carb? Routine servicing of the aircleaner would keep the carb clean for life. The pilot screw should be 1.5 turns out approx. with a small adjustment either way. Idle speed is set to a smooth low idle.If this doesn't fix it have you got something in the carb not replaced correctly? The float needle/float assy? How did you clean it? Have you introduced fluff/dirt into the carb and did you blow it clean with an airline?
Are you sure it is the carburetor's fault and not the mechanical fuel pump's? (the **** underneath your fuel tank on your right hand)?Anyway your engine is the same with Yamaha's XV 250 Virago so you are looking for the same carburetor.I found 3 on the Italian eBay but they don't seem to ship worldwide.
2001 Yamaha YZ80 Specifications
Engine
Engine Type
2-stroke
Displacement
83 cc
Bore x Stroke
47 mm x 47 mm
Compression Ratio
8.2:1
Engine Cooling
Liquid
Carburetion
Carburetor
26mm Mikuni
Transmission
Transmission
6 - speed
Chassis
Wheelbase
49.5 in
Ground Clearance
13.7 in
Seat Height
33.6 in
Fuel Tank Capacity
1.3 gallons
Forks
Forks
33mm Kayaba
Fork Travel
10.8 in
Shock
Shock(s)
Kayaba
Shock Travel
11.1 in
Wheels and Tires
Front Wheel
17 in
Rear Wheel
14 in
Brakes
disk/disk
Other Information
Intended Use
Motocross
Color Scheme
Blue
Cost when new
$3199
