Question about Craftsman Welding Tools
My new craftsman wire feed welder works great with flux core but it runs real bad with hard wire and everthing is set up correct
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
A good example of welding experience. I have been searching for a new welder machine last month and have found good one thanks to this review https://toolsduty.com/best-welder-for-beginners/, maybe it can be helpful for someone else.
Posted on May 19, 2019
    Top Expert:
  • Craftsman Master
  • 85,223 Answers
Please contact the manufacturer on this.
Posted on Feb 16, 2017
Anonymous
SOURCE:
co7196
Ned C Cook
  • 3433 Answers
SOURCE: wirefeed slips, i have the correct size o.9mm flux
It sounds like the feed spool is too loose or worn out.There should be a tension adjustment. What wire size are you using? On those off brands they usually use .035. and make sure the spool is not dragging. The wire spool also has a tensioner, or should have, in the center. Good luck.
Posted on Jun 07, 2009
Anonymous
  • 23 Answers
SOURCE: Campbell Hausfield wire welder feeds after trigger release!
has it done this before some wire feed welders the cheaper ones have hot switches mean that push wire all the time stuped i know but if it is not a hot switch than it is making contact some how and it could be inside the wip check it as best you can or take the wip in to where you got it from
Posted on Nov 10, 2009
rex foster
  • 18 Answers
SOURCE: I have a lincoln 140 pro mig welder.I am useing 35
Your Linner of the gun could have a kink in it.
Posted on Feb 19, 2011
luis_david
David Soto
  • 414 Answers
SOURCE: SMALL PUDDLES NO PENATRATION
Hi:
If you are using flux core wire you need to switch the polarity of the machine. With flux core wire, your ground clamp becomes positive (lead) and your gun the ground. All you need to do is switch the cables above the feed rolls.
That will take care of the problem
If this was useful to you, please vote. Thanks.
Posted on Mar 21, 2011
fixperience
  • 11 Answers
SOURCE: I have a 110 welder
sounds like theres a problem with the transformer/diode assy. thats where your weld current comes from. if your inclined, remove the cover you will see a wire wound transformer with a diode or rectifier assy. look at the wire leads, some have tube insulation over them . inside the tube insulation you will most likey find an inline thermal protecter either soldiered or crimped . you can remove it and get a new one through an electronics supply co. you can also look on the circuit board for a fuse there also may be soldered. or worst case, board or diode assy is burnt . hope this helps .
Posted on Jul 06, 2011
Wire wont feed on my welder
I would call miller and get a number for the closest repair station. They have a three year parts and labor warranty. 1-920-735-4505
Jan 10, 2015 | Miller Multimatic 200 MIG TIG & Stick...
Can I use 0.030 Flux Core Wire in my Lincoln Electric SP170-T?
Use the .030 flux core wire with the amperage settings for .023 solid. If you cannot find .023 settings then just set low power first and play with it to see what works.
Aug 26, 2014 | Welding Tools
Very little power at wire
try to use bare .032 wire and co2 shielded gas, If the equipment does not have a gas solenoid you may have to wire a solenoid to the trigger mechanism to get the gas to flow while the wire is feeding. The bare wire usually copper coated burns much hotter than the flux core when there is a gas shield. Also a .032 bare wire with a gas shield burns a a lower amp range and will get better penetration.
You may have to experiment with the feed rate and gas flow to get the correct setting, but the bare wire has a lot less resistance to current flow than the flux core and will burn a lot hotter when you use a gas shield.
At 115 vac there is not a lot of amperage left to create an arc and run the feeder and the rest of the unit , and the flux core wire takes a lot of amperage to burn both the wire and the flux . .
Apr 03, 2014 | Campbell Hausfeld ® 115V MIG Flux Core...
SMALL PUDDLES NO PENATRATION WELDER IS FARM HAND 115 VOLT MIG//FLUX CORE WIRE FEED PUT ON ANY SETTING NO DIF CANT FIND MODLE IT HAS CHPOWER.COM WEB ADDRESS
Hi:
Mar 20, 2011 | Campbell Hausfeld Welding Tools
Wire won't feed, motor runs and it grips the wire. I can pull it through by hand but it is hard to do .Is something in the line restricting the wire?
I wll check the gun liner and see if it is kinked. Check also your contact tip, must be same diameter as the wire, if you are running flux core wire, oversize your tip, example if wire is 030, then use a 035 tip. Check also drive rolls, for flux core must require knurled drive rolls instead of grooved ones.
Dec 18, 2010 | Campbell Hausfeld 115 volt MIGFlux Core...
I have a century powermate 70 mig welder and using .30 fluxcore wire. the machine says that it is gasless also. the machine will not weld right. is this the right wire or what could be wrong?
Check that your ground clamp connection to the weldment is secure (tight).
you can weld with the shielding gas, or without.
by not welding right, what exactly do you mean?
Jun 29, 2010 | Welding Tools
Difficulty changing the wire
check the tension on your drive rolls. Also check if the drive rolls are correct for that wire size.
Jun 27, 2010 | Century 80GS Flux - Cored Wire Feed Welder
Handler 140 wire jerky when welding
make sure rollers are clean and slots not wore out check alignment
do not over tighten wire feed so it smashes the wire
flux wire is hard to get a good setting
make sure if you can set it for gas welding it is not on this setting
Apr 06, 2009 | Hobart Welders 500505 Handler 140 MIG &...
Welding Tools Logo
899 people viewed this question
Top Craftsman Welding Tools Experts
Marvin
Marvin
wadingriver
wadingriver
Robert Wooley
Robert Wooley
Are you a Craftsman Welding Tool Expert? Answer questions, earn points and help others
