SOURCE: HP Deskjet all in one printer F380, won't feed paper through when
if there is a button beside the red flashing led just push it it will then load the paper could be it is not sensing the paper or perhaps the papaer is not pushed in far enough i have got an old hp and it does it all the time
SOURCE: Both paper feed and power lights flash after printing several pag
lean head-eject ink ruler & clean point of contact betwin cartridges and head-ink unit.
SOURCE: hp deskjet F380 will not print gives message out
how to solve hp desk jet f4288 incompatible error showing display
SOURCE: paper feed not working. green button and orange
I assume you mean that the power and resume lights are blinking. This signals a carriage stall. Open the top cover, if the cartridge cradle moves to the right, it isn't stuck and may be a one-time issue. If it is stuck, unplug the power to the printer. Open the access door and observe the carriage position. Clean any lint or paper pieces out. Remove any obstructions. Move the cradle and continue checking for lint, paper and obstructions until the entire area is cleaned out. If the print carriage started out on the left side, return it to that position to make sure the cartridges are back in the capping station. Look inside the printer along the cartridge cradle path for obstructions and remove any. Remove the rear access door and check for paper pieces, remove any obstructions.
Plug in and turn on the printer and see if the carriage returns to the left and reseats itself in the capping station. Close up the printer.
If this doesn't work, the printer may need service.
I hope this helps.
