Sewing Machines Logo
J
Janie Harris Posted on Feb 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Feed dog on Necchi 681c has drop,how do I fix it?
R.A. Ellis
Level 3:
  • Necchi Master 12,731 Answers
  • Posted on Feb 14, 2017
R.A. Ellis
Necchi Master
Level 3:
Answers
12731
Questions
Helped
2618413
Points
59176
A lot of machines have a control knob/lever that raises and lowers the feed dogs. However, remember that when the control is activated, the feed dogs will not rise until the machine actually begins to stitch.
If the feed dogs do not rise, then there is most likely a problem and needs to be serviced.
How to I drop the feed dogs on a Necchi Julia Supernova? There is a knob on the right side of the machine that should drop or lift the dogs, but it doesn't work.
There is a button with two "prongs" or wings. Rotate the prongs clockwise about a quarter turn, to face the square mark (Q in the diagram) then press it down. It will stay down. To raise the feed dogs, turn the prongs anticlockwise (to S in eh diagram) and it will pop up
https://www.manualslib.com/manual/1205574/Necchi-Automatic-Supernova-Ultra-Mark-2.html?page=7#manual
2answers
Necchi 4575 feed dogs won’t work does not push material through
If you raise the presser foot, set the stitch length to a 3 or higher, then slowly press the foot control, can you see the feed dogs rise, move backward, then drop and come forward again? If they are not moving, the feed dogs have seized. If they are moving but do not rise above the needle plate, then you have them disengaged.
If they are seized, resist the temptation to run the machine anymore until you can get it serviced. It could damage the motor causing more repair cost.
If they are disengaged (dropped), then you need to find the control lever or dial that engages them.
I have a Necchi 537FA and I want to know what the knob (on the right hand side) with the dot and knit symbol does. This knob is the last one on the right hand side. Thanks in advance for the help.
I suspect the knob on the lower right hand side is the feed dog knob. The "knit" symbol is for the feed dog. One setting drops the feed dogs so you can move the fabric yourself, ie free motion quilting. The other setting raises the feed dogs so the machine will feed the fabric for you.
to find a manual, Search the internet:
Brand + Model + the word "Manual"
1helpful
Can the feed dogs be dropped on a Necchi 215A-B-BS ?
If you do not have a button or lever on the outside you may have a button or lever under the slide plate, if you have neither then you will have a raised plate in your attachments
2answers
Necchi 4595 feed dogs keep dropping
Tighten the screw under the plate near the feed dog
1helpful
Feet not feeding and thread bunching up
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
HI THERE I HAVE BOUGHT A NECCHI 681C SEWING MACHINE SECOND HAND WITH NO INSTRUCTION MANUAL , I CANT GET THE MACHINE TO FEED THE FABRIC AS ITS SEWING IT JUST SEEMS TO SEW THE SAME ROW AGAIN AND AGAIN ??? I...
What is your stitch length set to? Is it possibly set to a low number? should be 2 or 3 for a normal stitch.
There is a website for the USA Necchi importer, http://allynint.com/index.html, Contact Information
necchilogo.gif contacts-no-e.gif Maybe they can help you obtain the manual for this machine.
1helpful
2answers
My necchi mod.910 i cannot get the machine to do zigzag stitch, and straight stitching is a problem - i have to pull the material in order for it to move
The Necchi machine has a lever in the bobbin area that lets you move the feed dogs up and down. If you accidentally moved that, the feed dogs are in the down position and won't feed the fabric forward. Make s ure you can feel the feed dogs slightly above the plate. If they aren't move the lever until they do. :)
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
