Cuisinart CBK-200 Bread Maker Logo
Posted on Jul 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unable to canceal program if I accidently hit start
The only way I know to solve this is to wait the whole 15 minutes after you unplug the machine
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Sep 29, 2009
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2174905
Points
14133
The easy way is to press and hold the stop/pause button for about 15 seconds - the fast reset.
Hello, I just purchased a trillium bread machine at a garage sale and am experience some problems. I've put all the ingredients in the machine and hit select to choose the kind of bread I want (Medium...
You are engaging the time delay switch when you start changing the time on your machine. Don't do anything with the clock or timer. You need to just choose the whole wheat program and the machine will perform as it is supposed to.
Can't connect to wireless router
1.Ensure ethernet cord coming from modem is plugged directly into internet port of router.
2.Powercycle equipment (Unplug power from home modem and router wait 15 seconds then plug back in
3.Open Network Connections XP:Start/Run/Type ncpa.cpl
Vista/7 Start/Search bar/Type ncpa.cpl
4. A.Right click on wireless connection the connection you use with router and hit properties,
B.Uncheck Internet Protocol Version 6/ Click on Internet Protocol Version 4 and hit properties,
C.Ensure Obtain an ipaddress automatically is checked
Ensure Obain a DNS server automatically is checked as well
5.Open Command Prompt XP:Start/Run/Type cmd
Vista/7 Start/All Programs/Accessories/Right click on Command Prompt hit run as administrator.
6.Type in Command Prompt: netsh int ip reset reset.log (Hit Enter after each command)
netsh int ip delete arpcache
netsh winsock reset
ipconfig /flushdns
7.Restart Computer
8.If still unable to access internet Disable Firewalls/Antivirus
We just bought the same one with two paddles, we waited about 15 minutes and it didn't start kneading... is it defective, should i send it back?
If you chose the "whole wheat program" it may have a delay cycle. Many whole wheat programs on bread machines Try turning it on with no ingredients in it. You won't hurt the machine doing this. If it hasn't started kneading within 30 minutes then it is definitely broken. For example one of my madhines is a Toastmaster brand. If I choose the whole wheat program it slowly preheats for 20 minutes before any kneading begins.
Machine error. unplug and call brother
unplug the machine for 15 to 20 minutes then try again. If not then within 2 seconds hit the keys in this order:
Menu-2-8-6-4-* (star key to left of 0) this may take a couple of attempts, but you will know when you are there because the lights will start flashing.
"maint. mode" then hit:
9-1-"set
and finally 9-9-"set"
this should clear up the error message if there is not a problem with the fuser unit.
2answers
My Whirlpool GHW9250L will not start and the "CONTROL LOCKED" indicator stays lit. Any ideas what to do?
Unplug it from the wall socket, wait 15 minutes plug again this methode unfreezes the unit.
6helpful
System error e000
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and wait 10 - 15 seconds and then replug and power up.
Problem solved.
4helpful
Machine says "unplug and call brother
9-1-"set
2answers
F-11
FIRST COMMENT
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes / Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
Replace failed component.
Top Cuisinart Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
Stan Ford
ADMIN Eric
ADMIN Eric
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
