SOURCE: printer
Heads are clogged. Has it been sitting for an extended length of time? Ink will dry up in the heads and tubes. Alot of work to take apart and clean and may still not work. Try to get a service manual at justmanuals.com
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
SOURCE: epson cx2900 3 in 1 printer
the problem might be the ink, change the cartridge maybe the ink dried out....
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
SOURCE: Epson CX8400 is printing blank
Hi
You need to replace the printhead
Pls vote us to keep us alive
SOURCE: have changed all cartridges on epson nx400. test
Hi The
ink reservoir doesnt have to be completely empty to fail. Replace the
cartridges. Some of the jets or all of them may be clogged especially if you
have not used your printer in a while. If there are cleaning instructions in
the manual clean the jets and then try to print from the printer's self test Goodluck
