When I turn on the vacuum, the brush rolls for about a second then stops. Any ideas?
SOURCE: My beater brush comes on
Same thing with my NAV22. Called them. They walked me through some troubleshooting and then they offered to send me a replacement power floor nozzle (the entire bottom piece). They said they don't want us to open it up to replace belts, so if you registered the product when you bought and it's been less than 5 years you should be all set...
SOURCE: Shark Navigator Vacuum roller jammed
oh..this happened to me often..if you can get n the corner where the thread s..i used a seem ripper to get the thread out and cut..if this doesn't help send a picture..the seam ripper is great cause it cuts through hair too
Did you check the bearing to see if its tight or free those bearing are probably in the brush ends
SOURCE: Why does the brush roller work for a second, then stop?
could be a loose belt or brushroll endcaps need to be cleaned
after you check this if it still cuts out its the electronic board
sorry not repairable
here is the belt if you need it Vacuum Belts Shark Navigator vacuums Lift Away Motorized Floor Brush NV350...
