Getting error message after error message, while trying to fax ten sheets.
SOURCE: printer, fax ,scanner,copier hp officejet 4255
hi....
pls click this link below. this is a link where you can get the software to download and select your operating system first.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=351125&lc=en&cc=us&dlc=en&lang=en&cc=us
SOURCE: HP Officejet J3640 All-in-One No Scan Options
When I triy to scan my document, I keep getting no scan options. Please help.
SOURCE: HP officejet 4355 all in one print fax scan copier to connect wit
Hi there, and welcome to FixYa,
You will find your driver at this site:
- choose your operating system, download and install,
plz let me know the result.
/Teis
SOURCE: fax not working Error 388
We had the exact same problem. Static on the line. We had the cable company check and sure enough our digital modem for the phone line was bad. The new replacement fixed the problem instantly.
SOURCE: Problem faxing-error message
Error 388:
Definition
There is too much noise on the line
for a valid connection between two fax machines to complete. The noise
problem might go away over time.
Solution
Retry
the fax reception at a different time when telephone line conditions
have improved. Call the telephone provider if line conditions fail to
improve.
Error 403:
Definition
During a V.34 transmission, the
local machine is unable to connect (handshake) with the remote machine
and is consequently unable to send a T30 frame. This occurs when the
line is disconnected or if line conditions degrade during the session.
Solutions
