Burned CDs always show as being fully used. That is so users don't think they can just copy files onto it. The way to find out how much free space is to subtract the amt. of space used from the capacity of the CD. Also most CDs are burn-once so after you burn it you can't add or delete files anyway. Only CD or DVD "RW" (read-write) discs allow you to re-use them.
SOURCE: Can't install Roxio Creator 2009
There is a patch from Roxio to resolve this error!
http://kb.roxio.com/content//kb/Creator/000217CR
Deadog4201
SOURCE: roxio creator 2009 burning issues
Here's a few things you can try:
1.) Download Service Pack 3 for Creator 2009. This updates the software and is recommended.
http://www.roxio.com/enu/support/c2009/software_updates.html
2.) Update your CD/DVD burner drives. This can be done by going to the manufacturers website and checking for updates. (Ex: If you purchased your computer from Dell and it came with a built in burner, you'd check Dell.com for updates.)
3.) Update the PX Engine. This is Roxio software that communicates with the CD/DVD burner drives.
http://kb.roxio.com/search.aspx?URL=/content/000070GN&PARAMS=set-locale=en
4.) If all else fails, try visiting this KB article:
http://kb.roxio.com/search.aspx?URL=/content/000008GN&PARAMS=set-locale=en
SOURCE: I have roxio creator & my dvd 9.0 de ; how do i burn my movies
I am trying to burn a movie onto a dvd using Roxio easy cd & dvd burning. The problem is that when I do burn it, it burns as a data disc. I try other things on it and it says to use the disc copier application to burn a dvd. I have searched everywhere on this progmram and there is nothing that says disc copier.
SOURCE: ROXIO CREATOR 2011 SPECIAL EDITION
I have window 7 and Roxio Creator 2011 Pro will not install at all.
