How about trying a DVD Burner? Leawo DVD Creator is able to burn DVD from any video and photos.The built-in slideshow video maker can help you convert your photos to slideshow videos and burn them to DVD. You can know more about the DVD Burner from its official site. Easy to Convert Any Videos to DVD Disc
Create the multiple slide shows and store them in a directory that you have created on your hard disk just for those slide shows. When all the slide shows are present in that directory, start Roxio, use the Add Files function and go to that directory and select all of the files you want on the DVD. Name the DVD to something that indicates what is on it and start the Create/Burn to make your DVD.
Burned CDs always show as being fully used. That is so users don't think they can just copy files onto it. The way to find out how much free space is to subtract the amt. of space used from the capacity of the CD. Also most CDs are burn-once so after you burn it you can't add or delete files anyway. Only CD or DVD "RW" (read-write) discs allow you to re-use them.
SOURCE: I am trying to burn
hi,
Try reducing the size of the file and go for a simulation first if possible to see that it ends successfully.
good luck
SOURCE: 800452c Error using roxio 10 trying to burn dvd
Download and install the last version of DirectX
http://www.gamesforwindows.com/en-US/AboutGFW/Pages/directx10-a.aspx
SOURCE: my SONY DVD+RW DW-56A won't burn a DVD
I am suspecting that you are running into a copyright issue that wasn't removed when they made the copy.... or the copy was corrupted... will it play back on your machine ?
Robert
SOURCE: roxio creator 2009 burning issues
Here's a few things you can try:
1.) Download Service Pack 3 for Creator 2009. This updates the software and is recommended.
http://www.roxio.com/enu/support/c2009/software_updates.html
2.) Update your CD/DVD burner drives. This can be done by going to the manufacturers website and checking for updates. (Ex: If you purchased your computer from Dell and it came with a built in burner, you'd check Dell.com for updates.)
3.) Update the PX Engine. This is Roxio software that communicates with the CD/DVD burner drives.
http://kb.roxio.com/search.aspx?URL=/content/000070GN&PARAMS=set-locale=en
4.) If all else fails, try visiting this KB article:
http://kb.roxio.com/search.aspx?URL=/content/000008GN&PARAMS=set-locale=en
