Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
r
richie ireland Posted on Feb 07, 2017
How do you pair the 2nd bluetooth helmet to the r1200rt lc,both helmets are schuberth c3pro with scr pro bluthtooth
2answers
Bluetooth code for skull candy
The code will be on the booklet the came with the box
tip
Choosing the best climbing helmet for your head
Rock climbing is a very fun hobby but it can also be very dangerous. Wearing a helmet when you climb can be a life saver, but it is important
that you make sure that you are wearing the right helmet both for the
activity you are performing and for your head.
When it comes to selecting the right type of helmet there are two main types to choose from, suspension and sponge. The suspension helmets are very similar to a construction helmet, its a hard shell with a netting on the inside.
These are really great for vertical dropping objects but they tend to be a little heavy. The other type of helmets are the foam helmets. These ones are made out of a lighter-weight polystyrene or polypropylene foam with a hard shell over it. It works by absorbing the energy of the of the falling object in the plastic and will deform the foam permanently. The durability of the helmet depends on the thickness of the shell, but because the impact on the helmet permanently damages the helmet it may not be very effective for extensive use.
After you have chosen the type of helmet that you will be using, its time to head into making sure that you have the right fit for your helmet. Keep in mind that you
will be more likely to use a helmet that fits correctly and is comfortable, before buying you should test out the helmet like you do with a pair of shoes. Many of the top climbing stores will allow you to try on and test out the helmet to make sure that it fits properly.
There are two main features that you have to pay attention to when trying on and picking out the right fitting helmet, they are adjustability and the chin strap. You start by placing the helmet on your head with it straight on your head making sure that you don’t tilt the helmet because you have to keep your forehead protected. Next you want to shake your head from side to side, does the helmet move? If it does then you want to either look for a different size helmet or if you can adjust the straps on the inside of the helmet so that it fits snugly. Then buckle the chin strap, it should fit snugly on your chin and form a Y shape
around your ears. There should not be any slack in the straps and if you
wear a pack make sure that you can lift your head to look up while
wearing the helmet.
A few side notes to keep in mind when considering the helmet you want to get. If you are going to be climbing in a very hot or very cold climate when you buy the helmet make sure to take your headscarf or hat with you so that you get a helmet that fits with them underneath. Where you are going to be climbing can also have an impact on the helmet that you will buy, if you are going to be
climbing in a cold climate that has ice you will want to get a solid helmet that will protect you from falling debris, while if you are going to be climbing in a warmer climate you will want to get a helmet that has air vents to allow for air circulation.
on Jan 16, 2014 • Rock & Ice Climbing
My one set of Scala Rider teamset pro will not let the second set talk to it but the microphone works- any solution?
Do the 2 units pair up when you switch on ? If they do try swapping the units to see if the problem changes from one helmet to the other.
If it does then the problem is with one of the units, if it stays with one helmet then it may be a wiring problem to the speakers.If they dont pairup when you switch on try re-setting the pairing and start again. With the unit turned on, press and hold the CTRL button for 6 seconds till the light flashes red then blue rapidly then press the volume up button for 3 secs, the red/blue should flash 5 times to confirm reset done. Then re pair the units for intercom, switch both units on, when they are flashing slow blue on one unit press the CTRL and Intercom Buttons simultaneously for 6 secs so the red light flashes rapidly, repeat for the 2nd unit, they should both go to a solid red light within a few seconds then slow flash blue to show they have paired for intercom use. If this does not cure the problem you will probably have to send the units for repair.
Hope this helps
Tim
Motorcycle helmet built-in bluetooth Hawk Motorcycle Helmet model H-6607
call hawk tech support for any user issues. usually a user error.
I have a bluetooth headset mounted in my motorcycle helmet and I can make a bluetooth connection between it and my nokia 6727 but now I got another Nokia 3727 and when I try to pair it with my helmet - I...
It is very posible that it is not connecting, reason being: compatibility. U should get a bluetooth headset that is compatible to both ur phones n pair it, that should solve ur problem. For example I can use any of BH320, BH200, BH600 on my Nokia 6120c n other bluetooth headsets I tried wont b accepted. U can try them n c. Good luck.
Hard had
Yes, but it's not an industrial hard hat.. And you would be in breach of all sorts of insurance regs if you wore it on a site.
Petzl have two in their range that are rated for commercial use, The Vertex Best and the Vertex Vent.. See the link below for more info..
It's not worth the risk for a few quid less..
http://www.petzl.com/en/pro/helmets
4helpful
How to fit a snowboard helmet?
"Getting the right fit is the most important factor to consider when buying a Snowboarding Helmet: 1. Measuring Tape. Your helmet size is determined by the circumference of your head. Wrap a measuring tape around your head to get your helmet size. 2. Align the front of the helmet above your eyebrows and hold both straps until the helmet fits well. 3. Make sure there are no unwanted gaps between the helmet lining and your head. The back of the helmet should not touch the back of your neck. 4. The helmet should fit snug and nicely. 5. Try one of your favorite pairs of Snowboard Goggles and make sure they fit properly on your helmet. Please note that the producers of helmets all have different ideas on the shape of a human head. Although the size might be right, the shape of the helmet might be different from the shape of your head."
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
