Frigidaire was tub makes loud thump noise during spin cycle....
I have a Frigidaire FEX831CSO, during the spin cycle it makes a loud thumping noise, the tub is spinning out of control an knocking the exterior of machine. It is on level ground. Thx.
Re: Frigidaire was tub makes loud thump noise during spin...
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
There is a rubber belt between the motor and the rotating cylinder.
If it is frayed, then part of the belt is hitting something during the "wash" cycle, and rubbing much faster during the "spin" cycle.
Replace the belt.
Could be the spider arms are broken. You can confirm this by turning the tub by hand, if you hear any kind of thumping sound as you turn the tub, then the spider is broken. The spider is the support arms that hold the wash tub to the drive shaft. It's very expensive to repair.
If there is no thumping sound when you turn the drum, it could be that one of the supports or spring is broken. Hope this helps.
support bracket that supports the tub is breaking. stick your hand inside and push up and down and see if its coming apart. if u look at it when it runs does it wobble?(the tub) if not take a look at the pulley on the back and see if its wobbly.
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
It doesn't look like a motor problem !!! It seems like an unbalanced tub issue. The machin has suspension dampers and suspension rods, and it's look like one of them was damaged or "run away" from its location during machin's movement.
Goog luck !!
