SOURCE: GE Profile-electric oven
Copper, F3 means oven temp sensor is open. You need to replace the probe. Easy job. Part number I have for this is WB23X5340, but double check your model number. Look it up on the net to see what you are going after...Catriver..post back
SOURCE: Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
SOURCE: what does e1 f3 fault code on my oven mean
F3 means your oven temperature sensor is open. you will need to get it replaced. hope this helps.
SOURCE: What does an F3 code mean on a Tappan
This is your oven temperature sensor on your Tappan Oven.
T
hese codes are designed to troubleshoot your appliances and prevent further electronic issues from happening to your unit.
It is a simple repair that you can repair yourself and you can save a ton of money, also!
Once this part has been replaced, you oven should close properly and work just fine.
SOURCE: Whirlpool gas range model gw395leps00 error code e2 f3
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
