C57M70N0GB Neff multi purpose oven micro wave, grill, fan oven and combination cooking light won't come on at all. Have reset clock no problem. All other electrics work on the timer but only for 2 seconds. Have turned off at the mains and retried several times.
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
SOURCE: Microwave oven stopped working
This is most common in over the range microwaves. Cooking grease migrates into the door switches, resulting in the symptoms you list. Replace the door primary and secondary interlock switches and you should be cooking again. NOTE: be careful not to touch other wires! Even with the unit disconnected from power, if you happen to have a bad bleeder resister in the high voltage capacitor you can still get a nasty zap !
SOURCE: Have a GE Electric Cook Top oven with digital
Unplug the stove. plug back in and program a short clean cycle. If this does not fix it is eithe the selector switch or the electronic control. Verifying the switch contacts with a meter is the only way to be sure.
Eric
SOURCE: fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
