When installing screws into used components, gently rotate the screw backwards until the threads on the bolt go past the threads already in the component, then start to gently turn the screw in the tightening direction. (the reason is: you do not want to cut new threads, as this will damage and remove the current thread material, and the hole will be too big as a result)
Put a small amount of lubricant (oil, thread oil, ect) and proceed to tighten the screw(bolt).
In this case 11 ft lb. torgue
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: STIHL CHAINSAW MIXTURE SETTINGS
one turn high and low 66 has compesator carby willrun rich up high but will lean under load
SOURCE: stihl chainsaw 066 died
mr siegs
remove the muffler and look inside the cumbstion camber and look at the piston.if you see marks (score) on the piston the piston and cylinder are bad and need to be replaced.this is caused from a lack of lubercation to the cylinder,possible water in fuel,spraying starter fluid into the saw,bad oil to fuel mixture,old fuel has no lubercating value.any more questions please feel free to contact me
SOURCE: Stihl model chainsaw chain oiling rate
If correctly set, the chain will throw a light, thin line of oil off of the tip after running a short time. Set a piece of pasteboard at an angle for a target.
