Question about Stihl Garden
Stihl 066 cylinder to crankcase torque - Stihl Garden
  • 486 Answers
When installing screws into used components, gently rotate the screw backwards until the threads on the bolt go past the threads already in the component, then start to gently turn the screw in the tightening direction. (the reason is: you do not want to cut new threads, as this will damage and remove the current thread material, and the hole will be too big as a result)
Put a small amount of lubricant (oil, thread oil, ect) and proceed to tighten the screw(bolt). 11 ft lbs in this case.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Feb 02, 2017
Anonymous
SOURCE:
Anonymous
SOURCE: STIHL CHAINSAW MIXTURE SETTINGS
one turn high and low 66 has compesator carby willrun rich up high but will lean under load
Posted on Sep 03, 2008
steve_lima
steve
  • 181 Answers
SOURCE: stihl chainsaw 066 died
mr siegs
remove the muffler and look inside the cumbstion camber and look at the piston.if you see marks (score) on the piston the piston and cylinder are bad and need to be replaced.this is caused from a lack of lubercation to the cylinder,possible water in fuel,spraying starter fluid into the saw,bad oil to fuel mixture,old fuel has no lubercating value.any more questions please feel free to contact me
Posted on Mar 12, 2009
Greg Mills
  • 497 Answers
SOURCE: need torque specs
Lower crank 75 ft-lb Head 105 ft-lb No specific torque on connecting rods. Just dont over crank it. Thanks for using Fixya.com
Posted on Aug 20, 2009
Hollenback
  • 520 Answers
SOURCE: What is the red light
here is a copy from an article i was reading
It features a "red light" on the right hand side above the tuning screws which illuminates at a set RPM to assist in tuning the high speed mixture screw, which is great when using the saw out in the field as no tachometer is required to give the saw a quick tune before commencing work. It allows peace of mind knowing that your saw is always tuned correctly and not running a lean mixture which causes damage very quickly. Incorporated with this "red light" system is a rev limiter, so even if the saw is tuned incorrectly it will not allow the saw to over-rev due to a lean out condition and blow up the saw!!
Posted on Jan 02, 2011
barterjoe
Joseph Mueller
  • 346 Answers
SOURCE: keep burning up piston on
It sounds like you are running lean. Not a lean oil/gas mix but a lean Air/fuel ratio. This engine runs hot as a high performance engine. any air leaks such as crank seals, manifold gaskets or muffler gaskets can give you too much air for the fuel coming in.
Secondly from the fuel side:
Ethanol (curse it) combines with oils that have no nondispersants making a white chalky poweder in the fuel system causing less fuel to mix with air. any blockage or pin hole leak can cause less fuel to be brought into the engine thus less cooling and lubricating.
Your carburetor and fuel filter need to be serviced and adjusted correctly or they will affect the mix.
When done the engine should run no faster than 13,000 rpm top no load speed.
This engine should idle smoothly at 2,500 with no more than 150 rpm change
if the speed is not as listed above when the rebuild is done you need to go back into the machine.
Call up a shop like www.arcolawn.comto get a EDT8 tach. it is well worth the money.
good luck
Joe
Posted on Feb 12, 2011
Hello I have a Stihl 066 chainsaw and I am replacing the cylinder what are the torque ratings for the screws?
In this case 11 ft lb. torgue
Feb 02, 2017 | Stihl Garden
Will a 56mm cylinder kit fit a 064
http://sawparts.ca/products/stihl-064-066-ms650-ms660-big-bore-cylinder-kit-nikasil-56mm
It seems that YES a 56mm aftermarket cylinder is available for the Stihl 064. Looking at the kit you need to just replace Cylinder, Piston and rings, bearing bush and clips. Worth also replacing the base gasket too.
May 01, 2016 | Stihl Models 064, 066, Ms640, Ms660
How do i replace piston rings stihl ms170 chain saw
Part 4: Stihl chainsaw piston and cylinder replace / repair ...
? 13:54
https://www.youtube.com/watch?v=jCbMCkGqCIQ
Dec 15, 2011 - Uploaded by Andy Reynolds
Refitting the cylinder to the rebuilt crankcase on a Stihl 026 chainsaw. ... Part 4: Stihl chainsaw piston and cylinder replace / repair. .... Part 3 Stihl 026 chainsaw fitting the rings, piston, anti vibration mountings - Duration: 15:10.
Part 3 Stihl 026 chainsaw fitting the rings, piston, anti ...
? 15:10
www.youtube.com/watch?v=n9RbtjNc-nc
Dec 16, 2011 - Uploaded by Andy Reynolds
Part 3 Stihl 026 chainsaw fitting the rings, piston, anti vibration mountings ... Part 4: Stihl chainsaw piston and cylinder replace/ repair.
Oct 29, 2015 | Stihl MS171 12" Chainsaw
Repair piston rings
Remove the cylinder to expose the piston and rings,the rings should be lose around the piston, they should have a break in them so they can be removed and squeezed in to fit back into the cylinder
Aug 03, 2013 | Stihl Garden
Stihl 066 does not start. Replaced ignition module. Weak or no spark.
Are the poles on your flywheel blue? Are you using an open-air inline spark tester, or holding the plug against the cylinder and turning it over?
Jul 14, 2012 | Stihl Chainsaw 051 075 076 Drum Chain Saw...
Sthil 066 chainsaw
You are absolutely right, an 066 is a STIHL model chainsaw. Good job!
Jan 18, 2012 | Stihl Models 064, 066, Ms640, Ms660
Looking for a parts diagram for a stihl 066 chainsaw
The one with the two right angle connectors is the inlet line. The other is the return line
Nov 05, 2011 | Stihl Models 064, 066, Ms640, Ms660
066 stihl, have all screws out but can't split case.
Assuming all screws are out, intake, exhaust and cylinder, oil pump and all oil pump related items are removed Screw the clutch carrier back on to the crankshaft (this protects the crank threads) and tap the crankshaft with a brass hammer. (TAP not Whack.) The tapping should loosen the 2 halve of the crankcase. You must replace the crankcase gasket.
Apr 08, 2009 | Remington Electric Chain Saw
Garden Logo
525 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Joe Paxton
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
