SOURCE: Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
SOURCE: SPEEDTOUCH 576 WIRELESS MODEM driver
HERE is the manufacturer main link to download driver. page also has manual on installing it and config modem properties. http://www.thomson-broadband.co.uk/codepages/content3.asp?c=7&ProductID=511
SOURCE: thomson router TG585
do u do any frimware update for you thomson if you do u have to complete it
SOURCE: I have two routers Netgear DG834Gv3 and Thomson
sorry, can't be done. the key word here is "router".
WPS??
Wifi Protected Setup. Allows you to add clients to the network. I have the answer.
