SOURCE: Trying to connect my canon
Hi.
The WPS button wifi auto configuration does not always work, in fact it fails most of the time, depending to router and network configuration.
Before connecting the printer , ensure that configuration Mac, router and network is complete, and that the Mac is connected to the network.
Before connecting the printer ensure that you have the printer software, if you do not have the software, download if from Canon website.
Install the printer as suggested in the document below. You will need to follow the steps in software setup. At a point you need to connect the printer to Mac using an Ethernet cable. Then enter access point, remove cable and configure printer wirelessly.
Here configuration instructions.
Here config. for additional computer (if required).
SOURCE: Does the linksys-G support WPS or AOSS?
Good question, I have the same router & Brother HL-2280DW and ran the printer setup CD from Windows XP SP3 via temporary USB connection & it seemed to work. The WAN report on the printer itself says OK, however the computer can't seem to find the printer "No devices could be found on the network." I let setup make changes to Windows Firewall, not sure about Microsoft Security Essentials however. This seems like a nice printer/copier at a nice price but this setup is frustrating! PS If it's a security issue I'd like to say thanks to all the hackers for ruining technology for everyone, your junk is responsible for slowing down & complicating computers & technology in the world. Someone please do everyone a favor & start making antibodies that *kill* viruses & spyware & spam and clean & speed things up for a change! All these villians - Where are the cyber super heroes????
SOURCE: I can't turn wps off
This tutorial works on the assumption that your router has been flashed with the right version of DD-WRT. Before you can go on further with this tutorial, you must flash your router with the right version of DD-WRT. If you face any confusion, you can log in to the DD-WRT's website and check out the tutorial on how to flash a router with the appropriate version of DD-WRT. This tutorial has been very nicely written.
If your router has been flashed with the appropriate version of DD-WRT, then there is not much work to setup VPN Router. All you need to do is set up the configuration and you are good to go!
SOURCE: where is the Linksys E1000 wireless router wps button
You can download the manual from this WEB site.
http://help.ecobee.com/attachments/token/howroilplaxny3u/?name=Linksys+E1000_V10_UG_USA_NC-WEB.pdf
SOURCE: My router doesn't have a wps button and I am
In the Printer settings there is a wireless setup section. Use the user manual found here: http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx432#BrochuresAndManuals
