You could try Googleing it, if you havn't already. Another method I've used on other guitars was to carfully remove the neck from the rest of the guitar. Manufacturers often put the production year on a tag or even printed directly on the wood body under the interfacing part of the neck. Some risk= "what if I damage my guitar?"
T-60's were were the amp builders first guitar model and the first mass produced guitar to be CNC milled.
Production dates range from '77 to '87
I like the their thin necks, angular headstocks and body shape.
Hardware is just so-so.
Sounds like a bad power supply filter cap...the buzz you're hearing is the 60 cycles hum that filter caps reduce or (hopefully) eliminate altogether. It may also be related to the tubes but finding the bad one will require some work. Any friends have this same amp? If so, try swapping one tube at a time and see if you get lucky. If this amp is new take it back ASAP as it is a manufacturing defect.
Sorry but your post did not provide enough info. Are you having a problem with the volume control. Do you need a wiring diagram. What model Peavey bass do you have. For instance, the Peavey bass I have has active electronics ans requires a 9 volt transistor radio battery to power them.
