SOURCE: Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
SOURCE: HP 8500 Color Laser Printer- problem priting reds
the basic causes for this problem is either the foil is bad or weak. secondly the element in the fuser unit doesnt heat properly so try replacing it with a working one n see what happends.
SOURCE: cannot faind Ricoh Aficio SP C410DN Laser Printer driver
you can find the driver here http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11540&ricohmodelid=6342&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fcl410%2Fcl410en%2Ehtm
SOURCE: paper misfeed in ricoh printer
1.Remove tray and clean the feed roller with cloth and 'fantastic" or windex. Make sure you rub dry after cleaning. All of this should be done with a ragg not a towel. You don't want lint on your roller.
2.make sure end fence (back guide in the tray) in in contact with paper.
SOURCE: Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
