Samsung 40" Black LED 1080P Smart HDTV - UN40H6203AFXZA Logo
j
john galvin Posted on Jan 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung led TV model UN40H6203AF no picture no sound no backlights. Flashlight test shows letters on screen after pressing menu button. Standby light blinks 5 times after turning on.
Replaced Main and Power Board and still have the same problem.
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Jan 30, 2017
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006383
Points
237762
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
How do I get the processor/logic board to restart?
Is there any picture on the screen....does the menu show?
1helpful
No picture on my LG TV. Issue is either the LEDs or the LED driver on the Power Supply. LED+ sections on the Power Supply [62810801] give 79.3 volts. Is this a normal or a below power reading?
That is the right amount of voltage the issue is when one or more of the individual LED lights fail, the current changes and the power supply senses it and shuts down.
Samsung tv, model UN39FH5000FXZA. Have sound, no picture, black screen. no backlights. flashlight test shows image. What should I replace?
Lamps in the panel are bad...DON'T order the power supply like someone says on about every post he answers before testing the LED lamps or you will waist a lot of money.
TV has sound but no picture
The Audio and Video are two separate components and operate independently of each other. Therefore: The Video portion requires technical repair by a technician with the proper test equipment.
2helpful
Samsung TV (model UN40H6203AF) 40" LED. No picture, have sound. Flashlight test can see faint menu screen. Have replaced power supply & main boards to this point. Ideas as to what to do next?
Hi Terry,
If you can see the faint picture in flash light means the power supply and the main board is working. The real culprit is the backlight. Even one bad LED in the backlight will switch off the whole array. To repair this fault the panel has to be opened and the defective LED or LEDs are to be replaced.
This is a complicated, delicate and risky job and must be attempted by an expert only. You may end up damaging the screen permanently if you have not done it before and try to DIY.
Samsung LED TV UN40H6203AF No Sound. No Picture. Stand by light works but tv doesn't turn on. Also no Backlights. Flashlight test shows letters on screen after pressing menu button.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
1helpful
3answers
How do I fix my Samsung 40 LED TV that has sound but no picture?
Here is what to check when your TV is turned on, power light is ON, but no picture is seen or sound is heard:
1 - Be sure the component you are using (Xbox, Cable, SAT, ROKU) is turned ON.
2 - Check to be sure all cable and cords are securely connected to the TV inputs and component outputs.
3 - Make sure you are on the correct input as some TV's will show a black screen if there is nothing connected to that input.
4 - Unplug the input you are trying to use from the TV (such as an HDMI Cable) and plug it back in.
5 - Check for signs of damage on all cords and cables from the TV to all components.
6 - Make sure the TV is not in ENERGY SAVE MODE, press the button on the remote control to go back to normal mode.
7 - Unplug the TV for 10 minutes to see if there was a temporary one time issue with the TV.
8 - Disconnect the TV from power for 2 minutes, then when plugging it back in PRESS AND HOLD THE POWER BUTTON ON THE TV FOR 10 to 20 SECONDS to try and force the TV to reset.
9 - If after checking all these different issues, you may have a Faulty Power Supply Board, A Bad Capacitor on the Power Supply Board, Loose Wire Harness, or Loose Ribbon Connector in the TV itself.
10 - Most likely when a TV has the power light ON but NO PICTURE and NO SOUND, it is the Power Supply Board that has failed.
BTW, here are solutions for you to play iTunes movies on Samsung smart TV
How do I fix samsung tv no picture just sound
Since you have replaced the LED board and you can still see a faint menu screen, this would indicate the LEDs have blown! Replace the backlight LEDs.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
