I have a 800 fashionista. I got a "E4" error. On the button for the needle down position wont stay on. It will turn by hand but it wont sew using the peddle.
In case you are unable to view--here is the text:
The Singer 7256 Fashion Mate sewing machine has a top drop-in thread bobbin and an automatic needle threader. The digital display on the side of the machine is used to select different stitch settings on the machine. When the display reads error code E2, it means that there is a bobbing threading error, which may be caused by the thread looping or bunching under the fabric as you sew.
Things You'll Need
Pen
Screwdriver
Push the bobbin-winding spindle of the sewing machine back to the left.
Turn the hand-wheel toward you, hold the needle thread (thread on the sewing machine needle) and tug it lightly as the needle goes down and then raises up. A small loop will raise up through the needle plate on the sewing machine. Use the tip of a pen to lift the loop up through to the back of the machine.
Check the position of the needle. It should be seated in the sewing machine with the flat side facing the back of the machine. If it is not, remove the needle and reinsert it so that it is facing the correct way.
Remove the bobbin case. Use a screwdriver to turn the screw on the side of the bobbin until the loops of thread pull taught and are removed.
Remove any loose fibers or threads that may be stuck in the tension disks.
Reset the upper tension disks. Raise the presser foot lever up. Put the tension setting of the sewing machine on setting "4." Hold onto the spool of thread in your right hand and with your left, route the thread down through the tension channel, around the bottom of the disk and up the other side. When done correctly, the thread will click into place and slip in between the tension disks.
Set the thread bobbin in the bobbin case, with the thread passing over the top of the bobbin and then down to the right. Route the thread through the notch located at the left of the bobbin case and pull it through. Move the thread over the top of the throat plate and over to the back of the machine.
Tips & Warnings
Using incorrect bobbins may cause error E2 to occur. Not all plastic bobbins are the same size, so check the model number of the bobbin to ensure that you are using the correct one with your sewing machine.
Never turn the hand-wheel on the sewing machine away from you, as it will change the timing on the sewing machine.
Brother Computer Codes
E1: Make sure the presser foot is lowered before sewing.
E2: You chose a stitch other than a buttonhole stitch or a bar tack
stitch and you tried to sew with the buttonhole lever in the lowered
position. Raise the buttonhole lever.
E3: If you selected the buttonhole or tack bar stitch and start to
sew with the buttonhole lever raised, you will get the E3 code. Lower
E4: You hit the reverse button while the bobbin winder shaft was
moved over to the right. Move the bobbin winder shaft to the left.
E5: On automatic sewing machines,
the start/stop button was pressed while the foot controller was plugged
in. Unplug the foot controller if you are using the automatic function.
E6: This code tells you that the motor locked up because the thread
is tangled. Untangle the thread, make sure the machine is threaded
properly and that the proper tension is set before continuing.
the brand new stylist I just bought at a thrift shop for $15.99 had a sticker on it stating, "Broken, you fix, parts in back"... I got the lady to get the parts in the back, which was the box it came in and all the accessories. Took it home plugged it in and E4 came up. I took of the nose guard with the one screw on the side, reached in and turned the coggs gently, viola, it works great.. The little servo or motor if you will got stuck when turned off in a zig/zag decorative mode. eazy fix, great machine,
hope this helps..
Michaelalan Quilting
Your reverse reinforcement stitch button was pushed or needle position was pushed while bobbin winder was moved to the right. You can download a free manual brother-usa.com and you will see all of the troubleshooting and error messages there
It may be in bobbin filling mode. Can you turn the inner circular on the hand crank. If you can click it into position, this should engage the needle mechanism.
These machines are known to freeze up in the needle bar crank, even when only a couple of hours old. If it is less than a year old, a Brother certified service center will fix it under warranty.
