SOURCE: The carriage is stalled message on my hp officejet H470 printer
Check the printer again to see if a very small jam is present. If totally clear, press the Resume button. If same result, power the printer Off / On.
SOURCE: Snow Leopard 10.6.0 does not recgnize hp officejet 6310 printer
Your printer is supported in Snow Leopard. However if it does not work go to the following link and follow the instructions. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01846935&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Testimonial: "Thank you very much Clay, at last I could put my printer back to work. "
SOURCE: HP Officejet Pro - Printer Door Open Light Stuck On
There is a problem with the proximity sensor for the top door. I have took mine off and soldered the connections over to trick it into thinking the door is closed all the time. I am trying to source a new part
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Testimonial: "superb"
SOURCE: Hp Deskjet Pro Printer K8600
Hello.
Give this a try:
Go to Printers and Faxes and delete your printer icon.
In Windows 7:
1. Open Printers by clicking the Start button, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
2. Right-click the printer that you want to remove, and then click Delete.
Disconnect the USB cable.
Restart your computer.
Reconnect the USB to your computer.
Your computer should see your printer. Install the printer's Windows 7 driver, found here:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3434446&prodTypeId=18972&prodSeriesId=3434445&swLang=8&taskId=135&swEnvOID=4063
If still a problem, your USB printer cable is probably faulty. If not the USB cable, the USB port on the printer is probably faulty.
Hope this resolves your problem.
