Have been unable to find location of water filter on my american style fridge freezer the filter is long slim one and the manual does not show location on the fridge
Your ice delivery water soleniod has failed, you can locate the solenoids in the rear lower of the fridge freezer unit where the pipes for water delivery goes in to the unit, locate the Ice delivery solenoid and replace it, easy test is to place a test cord on each solenoid and chech for operation under pressure. Russ
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
IS THE FRIG A THREE DOOR MODEL
