SOURCE: necesito control remoto para memorex
Hola, por favor revisa en la direccion indicada abajo usando el modelo de tu control remoto y la marca y modelo de tu equipo.
http://remotefinder.rca.com/default.aspx?site=rca
SOURCE: CODIGOS PARA EL DAEWOOD TV DEL CONTROL REMOTO RCU403A
NO SE EL CODIGO DE MI CONTROL REMOTO RCA 403, PARA MI TV MAGNAVOX..... AYUDENME, PLIS
vaya a www. fitness.manaulsonline.com or www. remotecodelist.com
y baje codigo.
Dios le bendiga
SOURCE: tengo un control remoto universal sony cual es el codigo para un tv parker
tengo un televisor parker y no encuentro un control universal para el que puedo hacer antes de botarlo
SOURCE: C?digo para usar un control remoto universal para operar el dvd hyundai
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts. .
