Press the Dedicates and Eco action button at the same time. Here is an online resource for the manual, that is what is listed on page 20.
Bosch WTVC5530UC Manuals
SOURCE: dryer
it's the button that controls the end of cycle buzzer volume /on/off should be small lock image beneath button
SOURCE: My Bosch SHU9925UC dishwasher will
Go check this link it will help you http://www.applianceaid.com/boschDW.html#run
Hope that helps.........
SOURCE: signal
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
SOURCE: My gas dryer will not heat up.
Hi, The timer will not advance unless there is heat (if in the automatic cycle)
I would check the fuse first, here is how:
UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
If the dryer heats in first part of cycle and stops late in cycle, you will need to change the coils on the gas valve. Here is how:
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
