Paper behind the draw or the paper not properly placed in the draw. DO NOT STORE EXTRA PAPER in the draw because there is extra space the extra space is for 11x17
The error code C0204 deals with the first paper tray not lifting up correctly. What you can do is to turn the copier off and pull out all of the paper trays and turn back On. Once it is warmed up, push one tray in at a time to see which one codes out. To resolve the problem, there could be a piece of paper jammed behind the paper tray or if you have LTR size paper in the tray, do you have paper on both sides of the tray. Remove the paper from the left side of the paper tray or you may have to take the paper tray out to get to the piece of paper wadded behind the paper tray.... Good Luck
Two things 1) check to see if there is paper in the back of the of the tray where it meets the back wall (that would prevent the paper tray from rising. 2) there is an upper limit sensor on the paper feed (thats where the rollers are) so check to see if any bits of paper blocking the sensors. If you find it, reset the machine and it will see the tray.
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code. In Bizhub C350 that code means: C12C0: Hard disk recognition error You have the following options: - reinstall the hard disk - change hard disk or as a last chance change PWB-MFP
