Televison & Video Logo
P
Phil Banc Posted on Jan 22, 2017
I have a Mitsubishi WD-Y65 that was just turning off this morning after I turned it on. I left it off for a few hours and tried again and this time the red light stayed on. Sound like a bulb issue?
It never shows a picture, turns off before it shows.
5 Related Answers
Anonymous
  • 81 Answers
  • Posted on Apr 08, 2007
SOURCE: Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Simpson Neal
  • 236 Answers
  • Posted on Apr 10, 2007
SOURCE: no sound or picture now
The set may have shorted the horizontal out put transistor since it kept coming on sometimes. This could be cause by the driver transformer arcing causing a "spike" in voltage going to you horizoltal out put transistor. Stargazer
Anonymous
  • 240 Answers
  • Posted on Jan 13, 2009
SOURCE: No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Anonymous
  • Posted on May 15, 2009
SOURCE: Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
Anonymous
  • 3 Answers
  • Posted on Feb 16, 2012
SOURCE: My tv mitsubishi wd-60735 turns
Don't know if this applys to you but if you have purchased anything but Osram or Philips replacement lamp for your DLP tv then this is probably your problem.. The generic is VERY tempting in this recession but in this case generic is poison to your dlp tv... i have a Mitsubishi 60735 and went thru 2 generic bulbs when my tv kept shutting down on it's own and the lights on front would flash, i could cut it back on for 10 minutes then flicker and shut down again ..well since the bulb was new i thought it may be defective so i got is exchanged for another one ... after all of the post i have seen how much repairs were going to cost on dlp sets no matter what the problem was ..i was ready to chunk the tv out the door when the second lamp was doing the same thing.....!! well a last ditch effort to save my tv before i trashed it or taking it apart to dissect it.. was to buy a brandname lamp ... in my case i purchased a Philips ..it cost twice as much =/ ..i could just return it if it didn't work.. well it was the generic lamps that was causing trouble.. the brandname worked perfectly .. i am just glad the generic lamp didn't do any damage to my TV!!! I have done further research on the generic lamps and realized that the damage it could have done was not worth the money i saved when i purchesed it... Generic is a great deal In some cases (household cleaners, etc..) but in this case GET THE NAME BRAND!!!! the only name brands i know of for these lamps are Philips or Osram/Sylvania.. hope this helps others from this headache. Do your research don't by generic lamp replacements, your DLP set cost to much to risk it.
Fan noise running when tv is on
Mitsubishi rear projection DLP keeps turning off and shutting down. The red light then turns on for a while and then turns off. TV can be turned on again and works fine until a random shutdown occurs again. No fault codes are stored. No blink codes. No airflow warning messages. The original thermal sensor was replaced 8-1/2 years ago. Fans are completely clean and running smoothly. I fixed this problem by replacing the 8.5-year-old thermal sensor. The problem is gone. Mitsubishi thermal sensor part number 299P313010A. Manufacturer part number YS11A95B-C6. Do not use the connector plug. Strip the wires, and hard wire and solder the 2 connections. This might also apply to these models: WD-52631, WD-57731, WD-57732, WD-65732, WD-57831, WD-65831, WD-Y57, WD-Y65
2answers
My mitsubishi wd-65c8 has a flashing green light.. I have replaced the capacitors on the DM board and the same is happening.. what else could be the...
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Wd-y65 dlp, have sound, no picture, tv shuts down after about 30 seconds. tryed tv reset 3 times,did nothing
sounds like you need a new bulb, mine is doing the same and the lamp light is coming on.
1helpful
2answers
My y65 has a new bulb when I turn it on yellow light come on within a few seconds and a check air flow message come on the screen tv then turns off if I wait about 30 seconds I can turn it back on again...
ogrady1428,
I would check the filter on the fan intake first. Remove it and carefully clean it with compressed air.If this does not resolve your problem then I would remove the lamp and inspect the switch in the vicinity of the door for problems. Be very careful reassembling the unit once the door is removed. The interlock swich must be positioned correctly or you will get an error message. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains the problem and how to fix it.
Thanks for using FixYa and for the generous rating. We answer these questions for free.
hardrocko
My tv keeps shutting down when I turn on. The message on the the TV screen said that "the TV will be shutting down in a few minutes". I resit the lamp in the back of the TV and the TV works after I reset...
The first would be excessive dust causing inadequate airflow through the lamp cage. Cleaning the filter may resolve the problem.
It could also be that one, or both, of the temperature sensors could be defective. This is a known problem to the extent that Mitsubishi extended the warranty an extra two years on your model and similar models with the same design.
Mitsubishi Digital Electronics America, Inc (MDEA) 2006 DLP® Projection Televisions Models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD- 65732, WD-57831, WD-65831.
As part of our commitment to quality and customer satisfaction, MDEA is announcing an extension of the warranty coverage to replace the thermal sensor for the above referenced models. For a period of two additional years beyond the one year limited warranty, MDEA will cover the cost of the thermal sensor (parts and labor) at no charge. All other terms of the MDEA limited warranty will continue to apply.
Hdmi 2 wont work on mitsubishi wd-y65
It sounds similiar to a problem we've had with ours, all components would work in hdmi 1, but hdmi 2 would only work intermitently. They ended up replacing the digital board (fortunately we have the extended warrenty, I'm sure it's not cheap). Sorry hope this helps.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
