SOURCE: microsoft wireless multimedia keyboard 1.0A
I suppose you should reset the keyboard and mouse and maybe the access point itself. Try find small buttons on each devise and press them AT THE TIME. You may need somebody's help. Those buttos can by hidden under mouse and keyboard and should be on the top of the access point. This depend on the model, so please reffer to a manual.
SOURCE: How to deactivate internal keyboard - Dell Inspiron 9400
if you go to the control panel, to hardware, in the keyboard section you should be able to uninstall the internal keyboards driver which will stop it working.
SOURCE: wireless keyboard stopped working; mouse still does though
on this key boards problem is that they key pad circuit board has no mechanical connection or wire connection it merely lays across the circuit board loosing contact that's why if you squeeze the bach it starts working again
SOURCE: labtec keyboard quit working suddenly
Here is the sequence to connect keyboard and mouse to receiver:
Press Connect button on receiver, and within 10 seconds press the Connect button under the mouse. Wait 15 seconds. Then press the Connect button on the receiver and within 10 seconds press the Connect button under the keyboard.
-- Thatpat
SOURCE: Sakar 62350N wireless multimedia keyboard stopped working
k i had the exact same issue. read all these posts online and no one could help me. so i took matters into my own hands. after removing all the screws from the back of the keyboard (figuring i had nothing to lose) i came across a very simple setup. and if you follow the two power cords that run from the batteries you will see they are connected to a card. two thin pieces of plastic are supposed to overlap each other and using the pressur from the back of the keyboard being screwed to the front of the keyboard connect to the power card. weeeeellllll i figured it must not have enough pressure agains the plastic pieces and put a lil piece of a business card i ripped up on top of them to make the connection tighter. WHHHHHHHALAAAAA ! freakin works! bahahahaha
