SOURCE: Whirlpool Control Panel Repair
model # MH6150XLQ
LOST POWER. I CHECKED WALL RECEPTACLE. IT'S GOT POWER.
MICROWAVE IS DEAD. NO LIGHT..........NOTHING.
WHAT'S HAPPENED?
SOURCE: What would cause the touch
It may be a glitch that can be corrected by a hard reset. Unplug it from the power line for a minute, plug it
back in, set the clock, then try again.
It may have gotten moisture, contamination, or grease inside, which can happen if one cooks on the stove top without having the microwave's hood vent fan on.
It may simply need repair.
We repair microwave control units and touch panels / touch screens for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: Kenmore Microwave 62622 display says "locked" and will not operate
hold your finger on the locked button till the light goes out
SOURCE: Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
