Computers & Internet Logo
Posted on Jan 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony KDL-40XBR2 - powers on, backlight is on, no pic, turn it off and back on, same for 10 to 15 seconds, then TV does power off/back on by itself...most of the time picture then shows up.
When screen is black it's easy to tell backlight is working...nothing else will show up including menu or on-screen input indicator. Sometimes when the power off/on cycle occurs the screen will initially flicker for a few seconds before settling in. Once screen comes on picture is excellent as always.
  • 1 more comment
  • lkpeck1951 Jan 16, 2017
    additional note...no blinking lights with power off, when on green light is steady on
  • lkpeck1951 Mar 06, 2017
    Finally got the TV where I could remove back cover and for the life of me I can't see any distorted caps or any indications of excess heat on any of the boards. The TV did finally fail...wouldn't come on initially and then when it finally did just lines going across entire screen. I'm willing to just order a replacement board if I knew which one??? :(
  • Carlos L. Burgos
    Carlos L. Burgos Mar 06, 2017
    Hello ikpeck , If you get the manual, or model or serial number to any technical tv store, they may help you with these, as I can say, it is a power capacitor issue, or inverter video board. but for be sure, I suggest to visit your local TV tech store. remember its your money! :)
Carlos L. Burgos
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 620 Answers
  • Posted on Jan 30, 2017
Carlos L. Burgos
Expert
Level 2:
Prodigy:
Answers
620
Questions
Helped
218528
Points
723
Depending on your enegy, on home, if is variable or steady 110V
you can check these on your TV, but safety first, or seek a qualify tech:
1) bad capacitor for power module **
2) bad inverter board or capacitors burn.
good luck!
Sony kdl-50w700b tv no picture?
If you remove the back and look in the various openings to the panel can you see normal backlights?
Tv power cuts on power light lit no picture then Tv turns it self off, when picture appears there's waves in picture and tv turns itself back off and on with no picture just black scree
Hi Patty
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Sony Bravia KDL-46NX810 shuts off with 3D input only
Well written question but I would first call Sony Customer service to see if known issue or if the data base shows any reports or recalls for this issue.......
SONY BRAVIA - 40 XBR .TV will not tune into digital channels. We get a blue screen with No picture and states No Event Information and also states MPEG U1
Hi Douglas,
First of all, thank you for purchasing the service/repair manual of KDL-40XBR2.
Please email me at [email protected], I will send to you the copy.
Again, thank you so much!
Have a great day!
Mjsazon
1helpful
40xbr2 bravia kdl sony LCD tv. The screen shuts
Problems relating to the automatic turn on and turn off of a set like this usually point to the main board being an issue. For this set, I believe Sony refers to that board as the "AU" board.
It's probably not the G/Power Supply board, especially if it turns itself on. Power supplies will turn a set off, but rarely--rarely--turn itself on.
If there's no kind of extended warranty involved here,
you could be looking at $500.00 for parts and labor to repair this kind of problem.
As always, try any software/firmware updates Sony might have available on their website prior to pursuing a repair visit.
1helpful
Sony KDL-46s2010 4 red light blinks
I would suspect one or more of the miniature flourescent backlight lamps. One way to confirm this would be to power up the set with a grayscale image at 40 to 60 IRE. If one or more lamps is failing to light, a slightly darker horizontal area in the grayscale will give it away. Unfortunately, Sony will not supply any of the backlight components apart from a new LCD panel. Sorry.
1helpful
2answers
Volume control not working
Most of the time one of the switches under the control buttons are bad on the control panel of the TV.
1helpful
Tv immediately turns off
Four flashes indicates a problem with the backlight on the TV. It can be caused by the backlight inverter board (the power supply for the backlight) or by defective backlights in the panel It is USUALLY the backlight inverter board that is bad, but I have seen both components fail at various times. This set is fairly new and should still be withing the one year warranty, so you should contact Sony at 800-222-SONY to get it repaired. Be sure to rate this solution. Thanks!
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
