SOURCE: freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
SOURCE: deep freezer
I TURNED THE CONTROL TO OFF TO DEFROST MY FREEZER. WHEN I TURNED IT BACK ON THERE IT DOESN'T COME BACK ON AND THERE IS A LOUD BUZZER.
IS THERE A RESET BUTTON SOMEWHERE TO RESET THIS OR HOW CAN I GET IT TO COME BACK ON? I HAVE NEVER HAD THIS PROBLEM BEFORE AND OF COURSE I CAN'T FIND MY USERS MANUAL. IT IS A 1994 MODEL FB14 DSDRWPT.
SOURCE: why the deep freezer ice up inside top front
It freezes up because there's warm air going through the door or the gaskets are letting the outside air getting in.
SOURCE: i have a haier deep freeze model hcm050ec what is
I am assuming you have some refrigeration smarts. As a general rule the evap in a freezer is 10 degrees low than the box temp. Take the pressure of the low side then look on a P/T chart for that refrigerant and determine if it is where it needs to be. Usually somewhere around -10 to-15 degrees for a zero or colder box.
