SOURCE: Connecting SRS-BTM30 bluetooth speakers to my vista laptop
This has also been sending me around the bend. I resolved it by disabling the speakers on my laptop. To do this go into control panel, then hardware and sound, then change system sound. Select your speakers and disable them. This allowed me to play music through the speakers. You can also re-enable the laptop speakers after this.
SOURCE: In order to listen on any Bluetooth device I have
pair your bluetooth headset with your phone.
SOURCE: Audio has a whining noise when connected through Bluetooth
I also own a Yamaha nx-b02 unit. Mine whines too, but only when connected via Bluetooth to my Vaio f series or my friend's htc.
They work perfectly on my older Toshiba laptop wich is equipped with Bluetooth 1.1. I suspect the problem only occurs with Bluetooth 2.x equipped devices. (might be wrong though)
Can anyone else add their experiences please?
SOURCE: making my craig bluetooth speaker discoverable
Through basic hacking, the code 0000 worked for me....
I wish it came to me sooner!
Craig Electronics CMA3532BT is the model number -
A tiny cylinder speaker - sounds pretty good for the tiny $$$ too.
MikeFilosa
SOURCE: my blackweb rocktech Bluetooth speakers wont charge
First thing to check is your charger. Those go bad all the time. Find another one and try that first. If that is not it then you have some bad batteries. If this is new within a year they should be replaced free. If they are older then you are on your own.
Turn on the Bluetooth
In Bluetooth Off mode, press and hold the Bluetooth button for about 5 seconds until a beep sound is heard and the Bluetooth button backlight flashes blue.
Press and hold the Bluetooth button for about 7 seconds to change to
Bluetooth pairing (linking) mode. The Bluetooth button backlight will flash blue and red. then go to the Bluetooth settings on your phone and select it there and enter 0000 for the default password
Then go to the bluetoothT
