The web site was changed about a month or so ago so moderators cannot update the category.The web site was changed about a month or so ago so moderators cannot update the category.
First Moderator on scene can change Cat to Misc, or music. Once the Expert answers, in this case you, the Category is locked. You get 2 points, plus the points for your answer. Hope that helps, and thanks for using Fixya :>)First Moderator on scene can change Cat to Misc, or music. Once the Expert answers, in this case you, the Category is locked. You get 2 points, plus the points for your answer. Hope that helps, and thanks for using Fixya :>)
You can't post conmments that contain an email address.
Your question is best answered by Singer. Go to Singer.com & select your world region, since you did not state what country that you're from. Then navigate to Customer Support, then Contact Us. When you call, be prepared with your exact model number and serial number of your machine. for your convenience, The U.S. contact number is (800) 474 6437. Good luck!
Yes, it's really a Singer. Singer has many of there machines assembled in China or other countries, as most manufacturing companies do. If the machine has Singer's label and model on the front, it's still a Singer.
Probably operator error. Make sure the machine is threaded right, make sure the bobbin is threaded properly, change the needle.... even though you think the needle is sharp. Make sure you are using the right thread. If you have bargain thread, throw it out. Use Coats & Clark, which is still reasonably priced. My friend has a lower end Singer that was acting up ... loose threads on the bottom of the fabric, which means upper tension .... we did the simple thing of changing the thread. It worked, and the machine is sewing beautifully.
