SOURCE: MIXER PROBLEM
PLease advise what is the model of the mixer. If it is a Chef or a Major, it appears that the blades have not been fixed properly. Please push in till you hear a click
SOURCE: Electric current
The three pronged wire contains a green wire which is connected to the metal housing of the mixer. It sounds like either that wire is broken, or disconnected inside the mixer, or the service into which you are plugging the mixer does not have a ground wire connected to a proper ground.
Remove the rear cover and look for a green wire and make sure it is connected to the metal of the frame.
If it is then check the outlet you are using to ensure it is wired correctly.
