Pretty easy to get the wiring diagram providing your model is similar to the Side by Side with a control board. Here is a link=>
HERE
There are more manuals on my website=> APPLIANCE 911
replace defrost control board or timer and inside freezer the bimetal (located in at top and rigth of the evaporator coil, test the heat element conductivity with a voltimeter
Sounds like you could have a bad mother board. Very common problem with the GE models. It will shut compressor off, than everything starts to melt, then it comes back on. Replace main control board and it should resolve your issue.
The problem you are having is most likely a defective=> WR55X10473 Main Control Board. The defectiveWR55X10473 Main Control Board may have been caused by a defective=> WR60X10185 Evaporator Fan Motor. If your motor has a white thermistor in the connector you need the related fan motor WR60X10074. If it has a connector for a light you will need a=> WR23X10467 Fan MotorReason I am telling you this is because if the fan is defective it can again damage the Main Control Board. The same wiring diagram is found=> HERE or HERE by clicking on the wiring diagram.Listen to this video because it explains what I am trying to say. GE Refrigerator Fan Motor DiagnosticsIf you would like I can walk you through the diagnostic's to see what is going on. I am here should you have questions, Thanks John Tripp Appliance 911
You should have included instructions that came with this board and the serial# is what dictates if a wire is cut or not on the main board. there also might be a wire on the harness that plugs into the wall that needs to be cut although I have yet to find one.
The provided link has pics of the instructions. just check your serial # to verify and follow the directions
