SOURCE: I have a
There should be a small lever on the base in front of and below the bowl. It will move to 2 positions. It sounds like you have it set for the small bowl but are using the large bowl. Press down on the lever and move it to the other side. If I'm right, that should correct the problem.
SOURCE: hobart a200 will run just fine without anything in
Short answer: something is worn/broken inside the mixer's transmission.
Longer answer:
Since none of the three gears operate, the problem is most likely on either the worm gear shaft (probably the brass worm gear itself) or the "transmission shaft" (ironic name as all three shafts could be called transmission shafts). If you're up to the task of disassembling the transmission, which is a very messy task, you'd probably find the problem on one of the two smaller shafts inside the transmission. You'll most likely find either a broken key or worn brass worm gear. Both of these items may have enough holding strength to operate under very light loads (such as an empty bowl) but slip once a load is presented.
Also check the planetary key. Remove the planetary by removing two nuts on the underside of the transmission, where the attachments attach (careful, as the whole thing will drop once the second, thin nut is removed). You will find a long key on the shaft (or in the planetary gear, whichever one it sticks to). Make sure it's not broken, and re-attach the planetary.
