Televison & Video Logo
P
Pamela Wyant Posted on Jan 13, 2017
Where is the pause button on one for all remote
What do all the symbols on a roku remote do
Which remote do you have? The * symbol is used to delete a channel that you no longer wantThe three buttons that look the same as on a VCR remote operate similarly. The pause / resume button will pause and resume so if you have to answer the phone or check on the baby, you can use the pause / resume button so you won't miss anything The fast forward and reverse button works on some movies, but not all.
Pause button not working
If all other buttons work properly, and only Pause button doesn't, it might be due to the internal fault to the remote control. Open it and clean it. To know how to check and clean a remote control, this site will give you more details.
2answers
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
multi-zone.
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
4. SUBTITLE
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
1helpful
2answers
How to program a crimestopper remote control model #chx433tx
To program this remote-
1) Open hood or ground GREY wire @ pin #7 on 12 pin connector coming from Crimestopper control module usually located under dash.
2) Turn key to on position.
3) Press red programming button coming from module 4 times, after a few seconds the parking lights on vehicle should flash 4 times.
4) Press button #1 pause, #2 pause, #3 pause, #4 pause on the remote you are programming, the lights should flash after ever button push. After all four codes (buttons) are learned, the unit will exit code learning mode. If not, turn off key and close hood. Hope this helps......BUZZ
7helpful
How do i unlock the panasonic dvd-s38 to play all region dvds
In addtion to the S68/S38 remote this hack requires a universal remote configured for the S58/S38 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
Neither the 'Play/Pause' nor 'Frame' buttons on the S58/S38 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S58/S38 remote press Audio, 1, 9, 8, 2, Subtitle
(it is not required but, if the TV is on, it will display the 'no go' icon after each key press - ignore it).
4. Using the other remote press Pause.
5. Using the S38 remote press 0.
If so, the DVD is region-free.
63helpful
Just bought a lg dv550 and am looking for the multi region code
1. Press the Open button on your remote control to open the drive tray 2. Press the Pause button on your remote control 3. Press the 0 button on your remote control 4. Press the 0 button on your remote control 5. Press the 0 button on your remote control 6. Press the 0 button on your remote control 7. The onscreen display should now prompt you for a new region 8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 0button for multi-region playback 9. Press the Pause button on your remote control 10. Power off your DVD player 11. Power on your DVD player
Pause Button On Wii Remote Not Working
So you have a sticky button sounds like? from your statement it seems to be working fine off and on.
My remote is stuck on pause. There is a pause
Sounds like the still is engaged hit the button again to turn it off.
1helpful
Unlock dvd player Sherwood VD4106R
Press the Pause button on your Remote Control
Using your Remote Control enter the code 3, 1, 4, 1, 5 and 9
Press the 0 button on your Remote for Region free, 1 for Region 1 or 2 for Region 2
Power off your player and wait a few seconds
Power on your player
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
