SOURCE: Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
SOURCE: EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
SOURCE: I have a epson artisan 800 I'm tring to fax from
I took apart my artison 800 with 'paper jam' error and grinding noise. Sadly enough, it is the plastic gear attached to the stepper motor which is slipping and making the grinding noise. I tried to glue it and it worked once or twice and failed again. It is a design flaw and Epson should repair this for free if they are honest about this problem. Ir is not a user-caused problem.
SOURCE: Epson Artisan 710 won't print black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results..
Thank you!!
SOURCE: Epson Artisan 800...adf keeps saying paper jam,
ADF Motor Assembly has gears which crack. Replacement of ADF Motor Assembly normally required. Compass Micro Inc sells this part. Part #: 2132225.
