It appears that there might be a TSB (technical service bulletin) issued on this vehicle by Mitsubishi. Check with your local dealer to verify for certain. One link with brief summary of this on a 1998 model (yours might fall into this class too?) can be seen
here and is as follows:
1998 Mitsubishi ECLIPSE 98 - Transmission TCM PCM > POWER TRAIN : AUTOMATIC TRANSMISSION : CONTROL MODULE (TCM, PCM) [Part 103100 ]
TSB No: 01 NHTSA ID: 622435 , May 01, 2001 : Replacement:
Summary: subject regarding diagnostic trouble code p1390 pcm relearn.
A fuller discussion on a 1996 with this code can be seen
here. Scroll down to the answer.
Perhaps these will provide a bit of information prior to contacting your dealer. I've never worked in a dealership that charged for looking up & providing info on TSB's. Good luck.
If this helps to solve your problem then please take a moment to rate this post. - Thanks.
